Confused engine sensors
at t 2d
I just got my TTA a few weeks ago and it is definitely not running well. Not making any where near the power it should and idling very rough. I took it to a local 3.8 turbo guru and he plugged a scanner in to it. The manifold air temp, coolant temp, and volts are fluctuating wildly. We are thinking it is a grouding problem.
Any suggestions on where to start looking?
Has it thrown any codes? Fixing grounds is cheap to do, and worthwhile even if doesn't help your particular problem. If it(the ECM) is throwing a few codes over and over then It's probably the ECM like Jason says.
I was getting an intermittent "lean" code. Pontiac replaced the O2 sensor and it has not returned.
Any ideas where to start looking for a ground problem?
