Anyone with a untouched TTA mind checking to see where the negative cable from the battery is attached to the engine block.
If I remember correct (and the style of bolt used) it should be to the lower bolt of the turbo bracket ... so no 3 in the attached illustration ... however I could be wrong so if someone would not mind taking a look for me would be much appreciated.
