You may have needed a tune to lean it out some if your BLMs were below 120 on a scanner?If you drive alot, wear lots of aftershave! It'll cover the exhaust smell stuck to your clothes. For my purposes, I wouldn't do it again.
TT Tune is matched to set-up. BLM's around 124. Catless stinks more. I'm thinking about reverting to cat. Don't get me wrong, I like the power, but hate the fumes more.You may have needed a tune to lean it out some if your BLMs were below 120 on a scanner?
If you can get the BLMs to 128 - 132 it will smell much better. It's been my experience, anytime the computer is pulling fuel thinking its running rich that it tends to smell some and water your eyes if not ventilated well. I always tune to where the computer it adding just a tad rather than subtracting fuel due to the fact that most of the time, depending on model of car, whatever the BLM is, it will carry that to PE mode..if subtracting, it will continue to subtract that amount when in PE mode and not looking at the O2 sensor… Speaking of those, make sure the O2 has good cross-counts too, 0-255 in less than 90 secs, otherwise replace.TT Tune is matched to set-up. BLM's around 124. Catless stinks more. I'm thinking about reverting to cat. Don't get me wrong, I like the power, but hate the fumes more.edo:
