B&M Transmission Fluid
Stebo
Member
Has anyone used B&M Trick Shift in their transmission? Should I use the regular or the synthetic? The regular stiff says on the bottle not to use with electronically controlled transmissions. I don't want to do any damage.
Stebo
Your 200R4 is not an electronically controlled transmission, so no damage should be done to it.
FWIW, my grandfather told me once that there is "no miracle in a bottle".....but he never saw a car scoot on NO2 either.
well there is miracles in a bottle for other cases, but a 200r4 in decent condition is not one of them. If your tranny doesn't have any problems right now than most Dexron III with Mercron fluids will work great if I remember right two of the highly sugested fluids when I had my tranny built was NAPA and Shell. Don't worry about buying into any of the $8/quart BS like Royal Purple, you're better off with another psi of intake pressure :clap:
