souljasmooth
I just purchased a TTA and drove it 10 hrs home without any issues other than a Hot start problem. If I drive it for say 15 plus minutes, stop the car and start it back it, it wont start. It doesnt even crank. Dash lights will flash. When I turn the key 4-5 times, it will finally crank and start up. This happened about 5 different times. One time I tried to turn the car on at a gas station, and nothing happened. The funny thing was about 2 minutes before I got to the gas station, I started the car fine(4-5 cranks). The lights still flashed when I cranked it, but thats about it. I tried about 7-10 times with no luck. I even let the car sit for about 15 minutes and nothing. The gas attendent tried to wiggle the battery cable, and then tried to jump the car with no luck. After about 20-25 minutes, I cranked it and it started. I read that other people had this problem. It wasnt really clear on the other threads as to what the exact problem was. I really need to get this fixed. Does anyone know for sure what the problem is? Where should I start? If this helps my car is completely stock. Thanks in advance
