$3500 RPM BUILT BOP TH400 RMVB TRANS BRAKE CONVERTER REID
5000.00 BUILD FROM RPM FOR HIS PERSONAL CAR REID ROLLER OUT PUT SHAFT AND NUMEROUS HIGH END UPGRADES 1000 PLUS HP ALSO INCLUDES HURST SHIFTER AND TRANS BRAKE BUTTON AND TRANS CROSSMEMBER. FRESH BUILD
I can manage shipping on a pallet anywhere in the us. Most places under 200.00 ship
Does this work with the stock drive shaft and exhaust on a TTA or will it require a custom drive shaft ?
Sent from my iPhone using Tapatalk
What is stall on the converter ?
Are you going to use the driveshaft or are you restoring to stock?
I dont know the stall Im going to look at it more closely tomorrow and see if i can figure it out
This driveshaft is custom for the T400 and a 12 bolt.
I am going back to a built 200 tranny but I had plans to have this driveshaft cut to size
